P
PATPOWER
Guest
I have a macro that copy all sheet from a drawing and open new template and paste the sheets on. Then close old drawing and saveas the new one with the same name of the original one to overwrite it.
The problem is that I cannot save after the paste is done. It works for a while but not anymore and I change nothing.
Do you have any ideas ? here my code..It works well with the part and assy section.. Thank you
Dim vSheetName As Variant
Dim swView As SldWorks.View
Dim swDraw As SldWorks.DrawingDoc
Dim swAnn As SldWorks.Annotation
Dim swSelMgr As SldWorks.SelectionMgr
Dim SWNOTE As SldWorks.NOTE
Dim S As String
Dim swCustPropMgr As SldWorks.CustomPropertyManager
Dim SheetCount As Integer
Dim DOC As ModelDoc2
Dim boolstatus As Boolean
Dim longstatus As Long, longwarnings As Long
Dim PART As Object
Dim PARTTITLE As String
Dim X As String
Public Z As String
Public Q As String
Dim SWAPP As SldWorks.SldWorks
Dim swModel As ModelDoc2
Dim nErrors As Long
Sub main()
Dim Answer As String
Dim MyNote As String
'Place your text here
MyNote = "DO YOU REALLY WISH TO REFRESH" & Chr(13) & "ACTUAL DOCUMENT AUTHOR AND DATE?"
'Display MessageBox
Answer = MsgBox(MyNote, vbQuestion + vbYesNo, "???")
If Answer = vbNo Then
'Code for No button Press
MsgBox "OPERATION ABORT BY USER!"
Exit Sub
'Code for Yes button Press
End If
Z = 0
A = 0
Set SWAPP = Application.SldWorks
Set DOC = SWAPP.ACTIVEDOC
If DOC Is Nothing Then MsgBox "A SOLIDWORKS DOCUMENT MUST BE OPEN" & Chr(13) & "TO PERFORM REFRESH THIS WAY!!": End
Dim swDocTypeLong As Long
Set PART = SWAPP.ACTIVEDOC
EXT = Right(PART.GetPathName, 7)
swDocTypeLong = Switch(EXT = ".SLDPRT", swDocPART, EXT = ".SLDDRW", swDocDRAWING, EXT = ".SLDASM", swDocASSEMBLY, True, -1)
X = PART.GetPathName
PARTTITLE = PART.GetTitle
If swDocTypeLong = swDocDRAWING Then GoTo 2
UserForm3.Show
If Z = 1 Then Exit Sub
'boolstatus = swApp.CloseAllDocuments(True)
'Debug.Print boolstatus
'If swDocTypeLong = swDocPART Then GoTo 4
'If swDocTypeLong = swDocASSEMBLY Then GoTo 4
Set swModel = SWAPP.ACTIVEDOC
Set swCustPropMgr = swModel.Extension.CustomPropertyManager("")
swCustPropMgr.Add2 "DESIGN DATE", swCustomInfoText, " "
swCustPropMgr.Set "DESIGN DATE", Q
PART.DeleteAllRelations
Dim swEquationMgr As Object
Set swEquationMgr = PART.GetEquationMgr()
swEquationMgr.add -1, Chr(34) & "Autorun""" & "=" & "Application.SldWorks.RunMacro" & "(" & """" & "C" & ":" & "\" & "SOLIDWORKS" & " " & "MACRO" & "\" & "MACRO4.swp" & """,""" & "MACRO41" & """,""main" & """)"
swModel.SummaryInfo(SwConst.swSumInfoAuthor) = "PAT LAFONTAINE"
GoTo 6
2 Set PART = SWAPP.ACTIVEDOC
Set SWDWG = swModel
Set swDraw = swModel
vSheetName = swDraw.GetSheetNames
'For i = 0 To UBound(vSheetName)
SheetCount = PART.GetSheetCount
SWDWG.ActivateSheet vSheetName(SheetCount - (SheetCount))
boolstatus = PART.Extension.SelectByID2(vSheetName(SheetCount - 1), "SHEET", 0, 0, 0, False, 0, Nothing, 0)
If SheetCount - 1 = 0 Then GoTo 8
boolstatus = PART.Extension.SelectByID2(vSheetName(SheetCount - 2), "SHEET", 0, 0, 0, True, 0, Nothing, 0)
If SheetCount - 2 = 0 Then GoTo 8
boolstatus = PART.Extension.SelectByID2(vSheetName(SheetCount - 3), "SHEET", 0, 0, 0, True, 0, Nothing, 0)
If SheetCount - 3 = 0 Then GoTo 8
boolstatus = PART.Extension.SelectByID2(vSheetName(SheetCount - 4), "SHEET", 0, 0, 0, True, 0, Nothing, 0)
If SheetCount - 4 = 0 Then GoTo 8
boolstatus = PART.Extension.SelectByID2(vSheetName(SheetCount - 5), "SHEET", 0, 0, 0, True, 0, Nothing, 0)
If SheetCount - 5 = 0 Then GoTo 8
boolstatus = PART.Extension.SelectByID2(vSheetName(SheetCount - 6), "SHEET", 0, 0, 0, True, 0, Nothing, 0)
If SheetCount - 6 = 0 Then GoTo 8
boolstatus = PART.Extension.SelectByID2(vSheetName(SheetCount - 7), "SHEET", 0, 0, 0, True, 0, Nothing, 0)
If SheetCount - 7 = 0 Then GoTo 8
boolstatus = PART.Extension.SelectByID2(vSheetName(SheetCount - 8), "SHEET", 0, 0, 0, True, 0, Nothing, 0)
If SheetCount - 8 = 0 Then GoTo 8
boolstatus = PART.Extension.SelectByID2(vSheetName(SheetCount - 9), "SHEET", 0, 0, 0, True, 0, Nothing, 0)
If SheetCount - 9 = 0 Then GoTo 8
boolstatus = PART.Extension.SelectByID2(vSheetName(SheetCount - 10), "SHEET", 0, 0, 0, True, 0, Nothing, 0)
If SheetCount - 10 > 0 Then MsgBox "DRAWING COUNTAIN MORE THAN 10 SHEETS," & Chr(13) & "ONLY 10 FIRST WILL BE COPY," & Chr(13) & "SO CHECK TO MANUALLY COPY MISSING SHEETS."
8 PART.EditCopy
'If Right(M, 6) = "SLDASM" Then Set PART = swApp.NewDocument("s:\aaatemplates\solidworks 2010 template\fond de plan\ASSY-D_Orientech.slddrt", 12, 0.2794, 0.4318)
Set PART = SWAPP.NewDocument("s:\aaatemplates\solidworks 2010 template\DRAWING.drwdot", 12, 0.2794, 0.4318)
SWAPP.ActivateDoc2 "Draw7 - Sheet1", False, longstatus
Dim myDrawingSheet As Object
Set myDrawingSheet = PART.GetCurrentSheet()
myDrawingSheet.SetName "SHEET TO DELETE"
boolstatus = PART.Extension.SelectByID2("SHEET TO DELETE", "SHEET", 0, 0, 0, False, 0, Nothing, 0)
PART.Paste
Set SWDWG = swModel
SWDWG.ActivateSheet vSheetName(SheetCount - (SheetCount - 1))
Set swSheet = swDraw.GetCurrentSheet
Set swSelMgr = swModel.SelectionManager
Set swView = swDraw.GetFirstView
Set swView = swView.GetNextView
Set SWDWG = swModel
SWDWG.ActivateSheet "SHEET TO DELETE"
M = swView.ReferencedDocument.GetPathName
Dim MYView As Object
Set MYiew = PART.CreateDrawViewFromModelView3(M, "*Front", 0.1097457655955, 0.1648856124764, 0)
Set SWDWG = swModel
sSheetNames = SWDWG.GetSheetCount
boolstatus = PART.Extension.SelectByID2("DetailItem346@Sheet Format1", "NOTE", 0.4080223743143, -0.001548983140407, 0, False, 0, Nothing, 0)
Set SWNOTE = swSelMgr.GetSelectedObject6(1, 0)
Set swAnn = SWNOTE.GetAnnotation
S = SWNOTE.GetText
myDrawingSheet.SetName "Sheet1"
boolstatus = PART.Extension.SelectByID2("SET AUTHOR NAME & PROPERTY1", "SHEET", 0, 0, 0, False, 0, Nothing, 0)
'part.DeleteSelection (False)
If boolstatus = True Then GoTo 9
boolstatus = SWAPP.RunMacro2("c:\SOLIDWORKS MACRO\DWG.swp", "MACROFEATURE_MODULE1", "main", swRunMacroUnloadAfterRun, nErrors)
9 vSheetProps = swSheet.GetProperties
'Set swCustPropMgr = swModel.Extension.CustomPropertyManager("")
'swCustPropMgr.Add2 "DOCTYPE", swCustomInfoText, " "
'swCustPropMgr.Set "DOCTYPE", "$PRPSHEET" & ":" & Chr(34) & "DOCTYPE"""
'Set part = swApp.ACTIVEDOC
'S = swCustPropMgr.Get("DOCTYPE")
If S = " " Then boolstatus = PART.SetupSheet5("Sheet1", 12, 12, vSheetProps(2), vSheetProps(3), False, "PART-B_Orientech.slddrt", 0.4318, 0.2794, "Default", True)
If S = " " Then boolstatus = PART.SetupSheet5("Sheet1", 12, 12, vSheetProps(2), vSheetProps(3), False, "ASSY-D_Orientech.slddrt", 0.4318, 0.2794, "Default", True)
If S = "" Then boolstatus = PART.SetupSheet5("Sheet1", 12, 12, vSheetProps(2), vSheetProps(3), False, "ASSY-D_Orientech.slddrt", 0.4318, 0.2794, "Default", True)
If S = "" Then boolstatus = PART.SetupSheet5("Sheet1", 12, 12, vSheetProps(2), vSheetProps(3), False, "PART-B_Orientech.slddrt", 0.4318, 0.2794, "Default", True)
D = 2
3 If sSheetNames = D Then GoTo 5
SWDWG.ActivateSheet vSheetName(SheetCount - (SheetCount - D))
If A = 1 Then If S = " " Then boolstatus = PART.SetupSheet5("Sheet" & D - 1, 12, 12, vSheetProps(2), vSheetProps(3), False, "PART-B_Orientech.slddrt", 0.4318, 0.2794, "Default", True)
If A = 1 Then If S = " " Then boolstatus = PART.SetupSheet5("Sheet" & D - 1, 12, 12, vSheetProps(2), vSheetProps(3), False, "ASSY-D_Orientech.slddrt", 0.4318, 0.2794, "Default", True)
If A = 0 Then If S = " " Then boolstatus = PART.SetupSheet5("Sheet" & D, 12, 12, vSheetProps(2), vSheetProps(3), False, "PART-B_Orientech.slddrt", 0.4318, 0.2794, "Default", True)
If A = 0 Then If S = " " Then boolstatus = PART.SetupSheet5("Sheet" & D, 12, 12, vSheetProps(2), vSheetProps(3), False, "ASSY-D_Orientech.slddrt", 0.4318, 0.2794, "Default", True)
If A = 1 Then If S = "" Then boolstatus = PART.SetupSheet5("Sheet" & D - 1, 12, 12, vSheetProps(2), vSheetProps(3), False, "ASSY-D_Orientech.slddrt", 0.4318, 0.2794, "Default", True)
If A = 1 Then If S = "" Then boolstatus = PART.SetupSheet5("Sheet" & D - 1, 12, 12, vSheetProps(2), vSheetProps(3), False, "PART-B_Orientech.slddrt", 0.4318, 0.2794, "Default", True)
If A = 0 Then If S = "" Then boolstatus = PART.SetupSheet5("Sheet" & D, 12, 12, vSheetProps(2), vSheetProps(3), False, "ASSY-D_Orientech.slddrt", 0.4318, 0.2794, "Default", True)
If A = 0 Then If S = "" Then boolstatus = PART.SetupSheet5("Sheet" & D, 12, 12, vSheetProps(2), vSheetProps(3), False, "PART-B_Orientech.slddrt", 0.4318, 0.2794, "Default", True)
If A = 1 Then A = 0
'myDrawingSheet.SetName "Sheet" & D
Dim bRet&n bsp; As Boolean
Set SWAPP = CreateObject("SldWorks.Application")
Debug.Print "File = " & swModel.GetPathName
Debug.Print " " & swSheet.GetName
While Not swView Is Nothing
Debug.Print " " & swView.GetName2 & " [" & swView.Type & "]"
While swView Is Nothing
boolstatus = PART.Extension.SelectByID2("Sheet" & D, "SHEET", 0, 0, 0, False, 0, Nothing, 0)
PART.DeleteSelection (False)
A = 1
GoTo 4
Wend
GoTo 4
Wend
4 D = D + 1
GoTo 3
5 'swDwg.ActivateSheet "SHEET TO DELETE"
'part.EditDelete
PARTTITLE2 = PART.GetTitle
SWAPP.CloseDoc PARTTITLE
Set PART = SWAPP.ActivateDoc2(PARTTITLE2, 0, 0)
'PART.Save2 (silent)
'Dim i As Integer
' Set SWAPP = Application.SldWorks
' SendKeys "%{F}" 'invoke file menu
' For i = 0 To 3 'go down to the saveas dialog
' SendKeys "{down}"
' Next i
'SendKeys "{enter}" 'enter
longstatus = PART.SaveAs3(X, 0, 0)
If swDocTypeLong = swDocDRAWING Then GoTo 11
6 longstatus = PART.SaveAs3(X, 0, 0)
Set PART = Nothing
Dim Answer3 As String
Dim MyNote3 As String
MyNote3 = "DO YOU WISH TO CLOSE DOCUMENT?"
'Display MessageBox
Answer3 = MsgBox(MyNote3, vbQuestion + vbYesNo, "???")
If Answer3 = vbNo Then
GoTo 10
End If
GoTo 10
11 Set PART = SWAPP.ACTIVEDOC
Set PART = Nothing
Dim Answer2 As String
Dim MyNote2 As String
MyNote2 = "DO YOU WISH TO CLOSE DOCUMENT?"
'Display MessageBox
Answer2 = MsgBox(MyNote2, vbQuestion + vbYesNo, "???")
If Answer2 = vbNo Then
GoTo 10
End If
10 MsgBox "REFRESH DONE!" ' Define title.
End
End Sub
Dim S As String
Dim PART As Object
Dim X As String
Public Z As String
Public Q As String
Dim nErrors As Long
Sub main()
'Display MessageBox
Exit Sub
End If
Z = 0
A = 0
UserForm3.Show
GoTo 6
Set SWDWG = swModel
8 PART.EditCopy
PART.Paste
Set SWDWG = swModel
Set SWDWG = swModel
Set SWDWG = swModel
S = SWNOTE.GetText
D = 2
If A = 1 Then A = 0
A = 1
GoTo 4
Wend
GoTo 4
Wend
4 D = D + 1
GoTo 3
'part.EditDelete
'Dim i As Integer
' SendKeys "{down}"
' Next i
Set PART = Nothing
'Display MessageBox
GoTo 10
End If
GoTo 10
Set PART = Nothing
'Display MessageBox
GoTo 10
End If
End
End Sub
