K
kentkent55
Guest
I'm having a college project about thermal and flow study. I need to use solidwork CFD to do a flow simulation on a metal with a hot air constantly blow on it surface. I will using time dependent to solve.
Could anyone help me see the setup correct or wrong?
Assumption
1) Inlet speed at 25m/s and 80 degree Celsius .
2) The temperature inside the box is environment pressure and temperature.
Result
1) What is the metal (pink) and the box (solid) temperature at every 5 seconds?
Assumption
Result
