Solid works step file conversation
Aravinthtvt
New member
IN
While converting a large assembly which have too many parts to step file, it is taking very long time to convert. Is there any way to make it in short time?
FEA Model?
Ask this in the SolidWorks forum...
Regards, Wil Taylor
o Trust - But Verify!
o For those who believe, no proof is required; for those who cannot believe, no proof is possible. [variation, Stuart Chase]
o Unfortunately, in science what You 'believe' is irrelevant. ["Orion", HBA forum]
o Only fools and charlatans know everything and understand everything." -Anton Chekhov
Aravinthtvt,
I agree with WKTaylor. This is a SolidWorks question.
I have had experience generating and managing large models. This is well documented under SolidWorks.
[ul]
[li]Keep models as simple as possible. For example, don't use the screw models from McMaster Carr. Model your own simplified fasteners.[/li]
[li]Does your exported model need all of your design detail? Will the end user appreciate all of your detail? Create simplified versions of your assmebly for export.[/li]
[li]Do you have enough RAM in your computer? Is your computer properly configured for SolidWorks?[/li]
[/ul]
As far as I know, mechanical 3D[ ]CAD is the very worst thing you can do to a computer and network. Make sure everything is up to the job.
JHG
To reduce the time needed to convert a large assembly to a STEP file, consider simplifying the model by suppressing or removing small, non-critical features and parts. Alternatively, you can try exporting the assembly in smaller subassemblies and then combining the resulting STEP files.
