Buildtech2
Our Atrium is one domain with extraction points in the ceiling located at 3 different spaces in atrium. The total smoke extract rate is 71 cum/sec. It was assumed that equal amount of extract air will be extracted from 3 different spaces (24 cum/sec) though there is no physical barrier between these 3 spaces. However, we can extract only 50% if air (12 cum/sec) through the ceiling void from one of the space mainly due to restrictions with the beams and expected air (24 cum/sec) cannot come to the fan intake duct but that can be compensated from other spaces.
I am assuming that the smoke movement, regardless of the origin of the fire, will not be affected since the entire atrium is one common domain.
As per the principles of the smoke movement, the smoke will travel from below the ceiling creating an equally distributed smoke exhaust from the atrium.
lease see attached required air flow rates as per CFD in Atrium and possible air flow rates as per shop drawings.
Appreciate, if anybody can tell me if I am assuming correctly.
