DCBII
- Apr 15, 2010
- 187
AISC 341 requires connections in the seismic force resisting system (SFRS) to be detailed as slip-critical if R>3. I've traditionally thought of a seismic force resisting system as a SMF, SCBF, BRBF, etc, including anything like collectors directly attached to the system. I've always used slip-critical connections in these elements since they're likely to undergo large inelastic deformations as the system yields.
I've never really thought of diaphragms as requiring slip-critical connections, since they are supposed to remain elastic, and most of the deformation is occurring elsewhere.
I've designed a special reinforced masonry shear wall building with a flexible diaphragm steel roof. The beams in the roof act as the diaphragm's continuous cross-tie. There is a girder running down the center of the building that the beams frame into. Do the beam connections into/across the girder need to be slip critical? Is that the intent of AISC 341? Or is that over-specifying slip-critical connections? Slip-critical connections cost about 3x as much, and they would be otherwise unnecessary on this project. I suppose the beams are technically part of the SFRS, but I'm not sure AISC intended this provision to extend to the continuous cross-ties. To me the primary seismic force resisting system is the masonry shear walls.
Thoughts?
Thoughts?
