R.V.
- Jan 20, 2017
- 6
As a mechanical engineer who is involved with various weldments and other fabrications in steel and aluminum, I find it unusual to perform slenderness calculations on beams involved in bending. This may be very elementary to those in the structural engineering field but in my experience the slenderness ratio is generally used in column buckling and I have never used it with respect to beams in bending. As an example, when performing something as simple as the analysis on the rungs of fixed aluminum ladders, I have typically analyzed the welds at the HAZ, looked at the shear, and the bending, using the deductions for welded aluminum. When I look at examples in the ADM, I see the use of slenderness checks on almost every aluminum extrusion. It may be moot when I go through it all as we have typically used large enough extrusions governed by standards but is this a common check when designing with not only columns but aluminum beams that would not experience any axial forces?
