Slanted dimension leaders?
  • Thread starter Thread starter MichailS
  • Start date Start date
M
MichailS
Guest
Hello
I want to draw a dimension between two points where one is above and to the left of the other.
When I try the usual way, the dimension can only be positioned with either vertical or horizontal leaders. I want to dimension the shortest distance, so the leaders should be slanted at an angle.
I can make this happen by using construct lines and perpendicular constraints and stuff like that, but reasonably there should be a simpler way?
Start the dimension command,pick your two points, right-
click select "Aligned".
Edited by: tmonty
