Hey all,
I am needing to check an existing slab for a new mezzanine line load, but the slab is on a HD40 (psi) foam insulation and I'm not sure what to take as the subgrade reaction modulus since that is in pcf.
My thought is that I'd need to check the HD40 to support the load, and then check the granular below the foam with a wider footprint since the load will get spread out by the high density foam.
The load is pretty light so I can't imagine there will be any issues, but it is something I'd like to know how to check.
