SKILLS CHALLENGE (chain)
  • Thread starter Thread starter CPiotrowski
  • Start date Start date
C
CPiotrowski
Guest
Create a linked chain that follows a random bent curve with oval links, not circular. I am still working on this one so no help from me. GOOD LUCK!
Cain,
can you be a bit more explicit when you say oval links, or do you mean oval sprockets.
The file below is a pdf of an EXACT 1" roller chain construction I did as an exercise. No approximations or simplifications and with perfect meshing of the sprockets so that hidden line removal works correctly.
2006-08-08_023138_chain_path.zip
Note: the gap for the master link measures 25,3mm
DB
Edited by: Dell_Boy
thanx Piotrowsky
I was bored for nothing to do and dont have enough time to start any new challenge.I didnot understand clearly what u want to create? mechanism assy?? simple assy?? or what? plz upload a pic if u can
I dont mean that kind fo chain. What I mean is a chain link like something you would use to pull a car or a chain that holds a childs swing on a swingset. A standard chain. This is a very tricky model. I figured out how to make it but havent had time to do so. The chain cannot be straight, it wust follow a bending curve.
Edited by: CPiotrowski
hmm
Made as 1 part.
Made 1 link then patterned it with a rotation aswell as a translation.
Then added a curve to be used with a spinal bend.
** Problems are that the chain indivdual links also conform to the spinal bend. ( each link is bent)
** to solve u would prolly have to make it from a assembly. requiring much more time.
For just a visual impression this method is probably best.
Cain/Puupet,
Can you model the same i one line and add the twists and turns using warp ?
Puppet,
nice model and I think the comment
is very true. No point spending a large amount of time for an essentially cosmetic requirement when a relatively simple approximation will suffice.
DB
Edited by: Dell_Boy
Nice job puppet. That is what I was looking for. I will likely make mine this weekend.
Cian,
When you say useing "Oval" links, do you by any cnance mean a losenge? (i.e. a rectangle with a full rouns on either side?
if one could use a losenge, you could place a point at part level which would be used to asemble it to patterned points along a 3d curve, may take a bit of playing around to get it to work tho...
puppet, like your idea! quick and simple!
Dojo,
Very neatly done :)
Everyone that has posted a model has done a great job. Unfortunetly I havent had a chance to do this but it seems there are definelty more than one way to skin this cat. I like the mountain of chain. I will need to upload one of these parts to see how you achieved this.
Thanks for everyones participation. SOrry I havent been able to contribute yet.
Looks perfect DOJO.
hi all, i am new in pw3 and i am really impressed with that chain, can anyone bo a little more specific with a tutorial or something???'
Thx
hi
how are you draw chains spline?
Hello all, I am new to Pro-E. Been using for about 6 months. The long Chain link is exactly what I am looking for. Does anyone have a tutorial on how to create it. Would really appreciate the help.
gilphillips@yahoo.com
There is a great example on our site for both roller chains and welded steel chains. The Free Downloads page includes instructions, files (for both commercial and educational versions) as well as a video example.
http://www.mobiusid.com/free-downloads/
The roller chain was originally developed to help FIRST students.
Enjoy,
Tim
P.S. for planner curves/paths only
Edited by: tim.mclellan
