sketch problem
  • Thread starter Thread starter aval_29
  • Start date Start date
A
aval_29
Guest
im havin a problem with sketches, cannot constraint sketches etc... then i use the sketch doctor but still there still a red cross, what will i do? thanks
Various comments
This comment was extracted from the Autodesk discussion boards:
Reply From: mcgyvr
Date: Mar/31/06 - 20:35 (GMT)
Reply
Re: Sketch problem, please help.
post the file, or click (show constraints) and just delete all and start again.
3DCADTips Support Desk :cool:
More comments
Reply From: JDMATHER
Date: Mar/31/06 - 21:12 (GMT)
Reply
There are certain cases where a red cross is of little concern.
Another comment
Reply From: Howard Delano
Date: Mar/31/06 - 21:54 (GMT)
Reply
Perhaps you are neglecting to add a "fix" constraint to one of your points.
Howard
Using a fixed constraint
Date: Mar/31/06 - 23:20 (GMT)
Reply
I don't think I've ever used a fixed constraint since leaving MDT?
Reply
Reply From: Ray Dyson
Date: Mar/31/06 - 23:30 (GMT)
Reply
Interesting, I've just used several today and don't remember ever using any
in MDT.
Ray
Reply
in MDT.
Ray
Date: Apr/01/06 - 12:12 (GMT)
Reply
MDT automatically places a fixed constraint in the first sketch of every part as soon as you "profile" it. (Remember having to profile every sketch?) So I'm sure you did even if you weren't aware of how MDT was working. Often in the wrong place for the design intent, so you have to go back and delete it and then replace or add two location dimensions.
It sounds like you may not be using the center point as a base for your sketches. This was not so important in MDT but in IV its crucial. Just remeber, project the center point in your sketches.
