sketch a hexagon easy
  • Thread starter Thread starter provdevi
  • Start date Start date
P
provdevi
Guest
1. Sketch a construction circle.
2. skecth a rectangle , taking 2 corners at the points intersecting the circle and dimnesion line.
3. skecth a line starting from the intersection point of ver/horz axis with circle to the intersection point of circle and the dimension line of the circle which will be somewhat easy to draw the hexagon. complete the sketch through 6 points ( 4 int of circle and 2 axis, 2 int of circle and dimension line).
4. Constrain all six sides of the hexagon to be equal length.
5. delete the circle and rectangle.
1. Sketch a circle.
2. Hit the selection button, circle is still selected,RMB >toggle construction.
3. Draw six linesintersecting the circle in the rough shape of a hex, make sure thattwoopposing linesare horizontal or vertical.
4. Dimension across the flats, or dimension the diameter of the circle if A/C dim is desired.
5. Constrain the sides to be equal.
6. Adjust the dimension.
7. Done
Sip
This topic has been started in wrong forum. This is Part Modeling forum while the right forum is Tips & Tricks.
Another thing about this topic is that this tip has already been discussed here so many times before.
Israr
