S
songah
Guest
Hello, I am quite new to ProE and I have trouble applying the right constraints to get this mechanism to work.
Basically this is a simple lipstick case in which the pin from the dish(the thing that lipstick is placed in) is inserted into the vertical slot and the helix slot.
The helix guide is then rotated and the pin in the dish is supposed to follow the helix guide and move up or down.
I tried many things but I couldnt get this thing to work.
An asm file with the correct constraintswould be greatly appreciated since one picture is worth a thousand words especially to a novice like me.
Thank you in advance.
2009-09-04_101409_lipstickcase.zip
