Engineerataltitude
- Oct 31, 2008
- 83
A builder drilled holes for 5/8" Simpson Titen-HD's to be retrofit into an existing concrete footing about 20 degrees off vertical because of some as-built constraints in the building. Off vertical to the outside, not length-wise to the sill. The building inspector caught this and said he had to get the EOR on the project to OK it or not. It is in a fairly lightly loaded exterio shear wall in a small light wood framed house, but in a high seismic zone in California.
I've not encountered this issue before.
Any ideas where I might get some guidance on the structural implications of this off-vertical sill anchor bolt installation?
