Simply Supported Shaft
  • Thread starter Thread starter soccer8888
  • Start date Start date
S
soccer8888
Guest
Hi all,
I'm using WF1 Mechanica to model a shaft suspended between two bearings with forces acting on it (in one direction) between them. How would I best set this up? I've tried modeling it as a simply supported member, but I get errors saying that its not constrained enough. When the beam flexes, it should be able to move in slightly at the bearings so I can't lock it in that direction. I've also tried modeling the bearings in with it, but it just acts like its all one solid piece. What am I missing, thanks in advance for the help.
I tried doing this, but when it came time to do the rigid connections, I couldnt' select the surfaces? Not sure why...
On another note, how would you model a beam that has infinite (or close) stiffness and (close to) no mass?
Depends on the relative size of the model and loadings.
I've defined a material that has 1000x the E of steel, (density 1000x less if you need that)than steel. Most cases I can figure a relativly large beam size, for a 0.25" fastener lets say, if I model at 0.25" round solid beamwith my "extra stiff" steel, it is essencially infinatly stiff relative to the rest of the model.
So the beam element model specifications don't mean much, its more to do with the material assigned to it?
