Simple question regarding the Merge/Inheritance command
  • Thread starter Thread starter calamum
  • Start date Start date
C
calamum
Guest
Hi All,
I'm trying to import a set of surfaces (a CREO part) into another using the "Merge/Inheritance" command in the Get Data tab.
For some reason "Merge/Inheritance" is not selectable in the menu. Any idea how I can make it selectable?
I can select "Independent Geometry" and "Import" but not the others...
Any help will be appreciated.
cw
I believe the advanced assembly extension is required to access the "merge/inheritance" feature. Same goes for the "copy geometry" command
