RIcardo100671
Hi
I would be grate full for any guidance or a design for a simple requirement that I have.
While I have tried researching how to do this with online calculators and documents, such as those from Parker etc., not being an engineer, I am finding it over whelming and confusing.
Basically I know that:
- I need a Dynamic Reciprocating Seal
- The materials will be thermoplastic like polypropylene and nylon
- The Piston Outer Diameter is 64mm
- Operating temperature is Max 100 degC
- Liquid is Water
- Max seal requirement 12bar
What I need to know is:
- Appropriate O-Ring type and size
- Detailed spec for groove/gland on the piston
- Min gap between piston and cylinder
Could anyone please provide a design for this requirement or a simple calculator.
Many thanks in advance for any advice
- Liquid is Water
