Show the Weight (Instance or Component) in a Table
  • Thread starter Thread starter xcad
  • Start date Start date
X
xcad
Guest
Show the weight of each component from an assembly in a simple repeat region table or the weight of each instance of a family table in a 2d repeat region.
Open each part and create a relation : weight=mp_mass()
The system asks from you to calculate the mass of the part
Create a repeat region table, click :
Enter text > report sym > &asm.mbr.weight, parameter to a cell
Retrieve this table to a drawing which you have the assembly, and see the result, the system fills each cell with the value of weight of each component
Also you can use this tip to show the weight of each instance in a family table.
Just add a column to your family table with the parameter
