Show Erase Dimensions with Drawing Progra
  • Thread starter Thread starter hasan_t_almasri
  • Start date Start date
H
hasan_t_almasri
Guest
Dear all,
Thanks to all who is participating in this lovely forum.
and here is my problem.
I want to switch between two parts. One will be
suppressed and replaced by other in the model using
pro/Program.
Now, in Detailing. Since there is a dimensions at the
suppressed part, i want to dimension to be erased or
deleted with ever the part is suppressed.
Can i do that in Drawing Program and how because i was
trying all morning and for nothing!!
Help Files says that you can record a state then use it
and Program like this
IF FEAT_SUPPRESSED (ASSEMBLY_NAME , COMP_ID)
SET STATE <whatever>
ENDIF
is that correct and i would appreciate if someone from
the Pros would show me how can i do it.
Thanks to all
Hasan Al Masri
Following,
It is discouraging, that nobody could answer that.
I have a similar question.
