Show Cosmetic?
  • Thread starter Thread starter Pupp1286
  • Start date Start date
P
Pupp1286
Guest
I can't seem to figure out how to show a cosmetic AFTER it has been erased using the show/erase tool... The cosmeticsbeing used are being created using the Insert>Cosmetic>Sketch tool.
I've tried all different things, can't seem to get it back!
The only fix i've found is to delete the view and recreate...
Using WF4
Edited by: Pupp1286
You have to turn the "preview" off in the show erase dialog.
Thanks!
I don't think i would've ever figured that out... You need to do something completely different to get that to even pop up!!
You're welcome.
Completely and totally absurd UI. The only thing worst is what they did to it with Creo.
Whats different about it in Creo?
Reason i ask is that our company istalking aboutto making the jump to Creo2 eventually...
Too much to list. Ribbon interfaces that you can't modify. Erase things and you can never show them again. It might be OK by Creo 2, hard to say.
