Should we respect the ratio 1.4 second order over first order for columns carrying only axial loads ?
structural87
FR
hello
In section 10.10.2.1 of aci 318-11, it is stated that the ratio of second order to first order moments should not exceed 1.4.
I have a special reinforced concrete shear wall system where i am hinging the columns at their top and bottom so they can take only axial forces and relying solely on the walls for seismic resistance.
In this case, should this limitation of 1.4 still be respected since I don't have end moments at the columns top and bottom except the minimal eccentricity ?
I am using the software Etabs and this latter calculates the delta-ns to cater for small P-delta and provides an error message once the delta-ns > 1.4 while still showing that the percentage is within the limits even by magnifying the minimal moments.
Thx in advance for your input
Are you saying these columns with hinged ends have a P-little delta amplification exceeding 1.4? If so, then that would be very unusual unless the column is very long and slender.
What moment is being amplified -- the end moment due to a minimum eccentricity?
Yes this is correct. Not that slender I would say. i am talking about a column 800x250mm and delta-ns is coming large > 1.4.
The minimal moments are amplified but still within the P-M interaction curve.
The problem is that even if the moments are still within the interaction curve, from the moment that delta-ns exceeds 1.4, we need to enlarge the section and this is what i am asking about.
Always, there are 2 nonlinearity working together, the big P-Delta at story level and small P-delta for individual column buckling. For braced frame, the first could be ignored, however the later is indeed applied. Here the code gives you multiple options: either conservative method (the magnifier, delta_ns), or truly capture the effect by dividing the column to multiple segment. Either option you choose, 1.4 limit is to keep drift under 0.25, and that is not a small number at all and approaching it shouldn't be taken lightly. Actually the code goes little bit further to 1.4 instead of 1.33 corresponds to (1/(1-0.25)). Explore the options to increase (EI)_eff, hence higher Euler load and less delta_ns, in case you want the conservative method, this worked for me in many cases.
hello
If ETABS doesn't show the moments doesn't mean that moments do not exist. As others pointed out there are always imperfections (out of plum and local) and eccentricities of load application causing moments. The ratio of second to the first order moments is just a measurement of stiffness. Building codes in other countries give slenderness or ratio of axial to buckling critical load as means of assessing stiffness.
You need to apply the minimum moments provided in the code.
A P-little delta amplification of 1.4 is not believable for a column with regular proportions. If the column was very long and skinny, and loaded near buckling, then maybe.
Recommend you calculate the P-little delta amplification factor (B1 in AISC) and compare to what ETABS is reporting.
For a column with hinged ends, with single curvature bending and equal end moments:
B1 = 1 / (1 - P / Pe)
where:
P = column axial force for the load combination being checked
Pe = π^2 E I / L^2
Are you getting 1.4 for all columns in this story? If so, then it sounds like the P-big delta amp.
A column with a hinge on both ends would not have any P-big delta amp.
