Hi, I'm reassembling my oven and I have a question about the thermocouples, as seen in the images below. Regarding the images of section "B": in the top-left picture of this section, notice the little 'disc' on the shaft that sits between the two nuts; my question is whether those nuts should screw right up to that 'disc' or not. If they do screw right up to it then the thermocouple is then fixed fast and can't rotate: the images of section "C" demonstrate the rotation through which the thermocouple can rotate otherwise, if these nuts aren't screwed on all the way. The top-right picture of section "B" shows the left-hand nut having been screwed on all the way; the right-hand nut of this particular thermocouple can't screw on all the way because this particular thermocouple is a little damaged. When I was disassembling the oven, I noticed that these nuts were not screwed on all the way, leaving the thermocouples freedom to rotate; but I thought that this could possibly have been a mistake of the manufacturer's, or else that the nuts had become loose over time and needed to be tightened up again.
Section "A" just shows how the thermocouple fits in general with the oven.
