Well, it is and isn't. We had some very funny stuff happening. We ended up doing a lot of small mixer batches - if we had a litre too much water, the slump was 230 to 240mm, mix 10 minutes still the same, 10 minutes more, maybe 200mm. If a litre too little water, the slump would start out at 230 - go to 120 then go to less than 40 after 20 minute of mixing. The specs say to pump 80mm but can't be done.
So, we have let it go at 230 at the batch plant. When the Meyco160 is added at the nozzle, it sprays pretty well given that we are spraying with an excavator bucket rather than the robotic arm.
Had some good results of test panels - got our strengths. So, the contractor is spraying - while outside spec of slump, it is looking okay - but of every 5 batches or so, he loses one on the slump. Degussa guy was here and they are sometimes, if the slump on arrival is down to 150, adding 1/2 litre more of gelenium.
Ideal and to specs - not - nightmare to QA. Working okay? Seems to be with difficulty. Beams were cut of some panels and looked uniform without any appreciable sand layerings, etc.
