Shell Elements
  • Thread starter Thread starter Daniel R
  • Start date Start date
D
Daniel R
Guest
Trying to run a static analysis using shell elements on Mecanica through Wildfire. On version 2000i2 this was done through Mecanica menu, settings, and checking USE PAIRS. I can
There is an icon on the right in Mechanica that is for a new shell pair. Define your shells using that command. Under AutoGEM, select Midsurface to ensure that shells are used in the analysis.
