sheetmetal to solid conversion?
  • Thread starter Thread starter denncoa
  • Start date Start date
D
denncoa
Guest
Can you convert a part made in sheet metal to a solid part?
Nope, I don't use sheetmetal for this reason, preferring to create thin protrusions (or constant thickness solids) - you can go from solid to sheetmetal in this manner but not the other way.
Being in design I usually don't have a need for flat patterns, notches etc but being considerate of other functions, this approach is the most flexible...
The only way to convert to solid is to export th sheetmetal part as iges and recreate the part.
hello
I would be very interested to learn for what reason someone wants to convert a sheetmetal part to solid.
I understand the reason for conversion from part to sheetmetal
xcad
Someone might want to convert a sheetmetal part to a solid part if it was originally going to be metal and then was changed to a plastic part.
Yes you can. Create an assembly, add another part (which can probably be empty, aside from a coordinate system), then add your sheet metal part. Merge the two, using the other part as the active part. The other part will then be a solid with the features of the sheet metal. I have done this, but with features in the other part. CREO then merges the two. I use this to create complex channels that are on the inside of a cylinder.
