sheet set templates?
  • Thread starter Thread starter Barclay
  • Start date Start date
B
Barclay
Guest
Is there a way to apply a template to existing files within a sheet set? I attempted to point to the template that I want to use in the "page setup overrides file" line in the "sheet set properties" dialogue box, but nothing really seemed to take effect.
Cheers!
Once a sheet has been created, I dont think that you can "point" it to another template. It has already used a template to create the drawing when you opened the sheet. The overrides template gives you a way to publish a set with a different page setup, and that's all it does.
Cheers!
