durablack2
Automotive
I have one sheet metal assembly that made from 2 parts and is welded together. There are several bends on each part and each have several holes that need to line up at the assembly level. Would you guys typically separate the parts and dimension them in separate views or would you dimension them in an assembly view?
I feel as if I separate the assembly and dimension the parts in separate views this may indicate that there is some allowance for the holes to be slightly misaligned.
When manufacturing these parts they will be punched, bent, then welded together. I'm just curious what the best practices are for drawing these type of applications.
BTW, these are wide tolerance parts and currently there is no GD&T on this drawing.
