Tahoebrian
- Apr 24, 2021
- 1
Hi all,
I am going through and rethinking my shear wall approach and have come across a couple questions that I cannot find a definite answer on. I am hoping some of you can share your thoughts.
First question.. the 2008 SDPWS states that the aspect ratio (paraphrasing) is for high aspect ratio wall segments relative to other wall segments with lower ratio IN THE SAME LINE. Now suppose you have a wall line that does not have any lower ratio wall segments.. say for example just 2 segments at 3.5:1 (typical for the front of a residential garage). It seems like the aspect ratio would not be applicable since there are only two wall segments of the same ratio. Thoughts?
Second Question.. When calculating the wall height aspect ratio for a perforated shear wall, what would be a suitable value for the b term (shearwall length). It seems reasonable that the b term would be the sum of wall segments in a perforated assembly but I can find nothing mentioning this.
Thanks a bunch.
Thanks a bunch.
