Gustavo Barros
Hello guys,
In the API 650 Section 6 - Fabrication, there's a Figure (6-1) that provides criteria for shaping of plates to the curvature of the tank prior to installation in the tank, when they are required or not, depending on the thickness of the shell plate and the tank diameter.
I would like to know if somebody has more information about the consequences of the plastic and elastic effects on the steel plate, as well as the behavior of the stresses on the plate, when they are previously subjected to shaping or if they are made concurrently in the field.
Thanks in advance
Thanks in advance
