setting up a mechanism
  • Thread starter Thread starter KHECKEL
  • Start date Start date
K
KHECKEL
Guest
I am a new user of wildfire, havin problems with setting up a mechanism. what steps do i take....how do i create a body...
mechanism? what kind of mechanism?
I haven't used Wildfire, but in 2001, you need to assemble your parts using connections rather than the usual constraints. You will find this in the Component Placement window when you first assemble the parts. The first part in your assembly should be the base. All the subsequent moving parts should only have connections defining them. That should get you started.
Is there a book or tutorial dedicated to creating mechanisms?
hello
Look in :
C:\Ptc\proe2001\demos\demo\mdx, in your hard disk (I install proe in c:\ptc, directory)
some free videos about mdx from proecentral
and search for simple free mdx tutorials form the net,
it
Thank you, works real well
