setting ToString() decimal places
multicaduser
Industrial
In getting the sizes from the "ufs.Modl.AskBoundingBoxExact" function and creating a string from the distances, I'm having difficulty figuring out how to set the format decimal places to four using the "distances(0).ToString()".
In expressions I would use "format("%.4f",variable), but that doesn't work. Is there a way to set the decimal places directly or does it need to be done post conversion? Then there is the question of the function dropping trailing zeroes.
Can someone give me a hint?
tia
NX 12.0.1.7 Windows 10
Thanks again cowski, great help. Knuckle dragger that I am I found it a couple of minutes after posting.
distances(0).ToString("0.0000")
Alternatively: ToString("F4") will give you four digits.
