Session id
  • Thread starter Thread starter John Wayman
  • Start date Start date
J
John Wayman
Guest
Good morning,
I know that I can find the session id of a component in the Relations window.
What I don't know is, if I know the session id, how do I find the component it refers to?
Say I click on a note that includes a parameter, and I see that it reads
'NUMBER OF WIDGETS = &NO_OF_WIDGETS:220'
How do I find out which component has session id 220?
Random stabbing is the best I can come up with so far, but that is no good if the component is a sub-assembly.
Any ideas?
John
Try typing in &model_name:220 into your note. As long as the session ID number you type in is the same as the part you are looking for, the part name will be displayed. You can then delete the note when you are done if you would like.
