Servo motor definition for a slot
  • Thread starter Thread starter atalet
  • Start date Start date
A
atalet
Guest
Hi all,
While defining a servo motor for a slot connection, should I use a motion axis or a geometry servo motor?
After defining the servo motor I would like to make a dynamical analysis. An example can be found attached. Helps are appreciated.
2009-03-11_092906_slot.zip
Edited by: atalet
I could finally find the solution.
Moving the part along a slot is not related with the servo motors but the initial conditions. While defining initial conditions, "tangential slot velocity" should be defined.
The movement can be viewed by defining a dynamical analysis and to have a dynamical analysis material should be defined for the moving part. That was the trick.
Edited by: atalet
