select only unsuppress parts in sub-assemblies
MANox
130
Hello everyone,
I have code for select all unsuppres part in assembly:
Code:
  Sub getAllComponents2(ByVal comp As NXOpen.Assemblies.Component, ByRef allComp As List(Of compDescr))
        Dim c As ComponentAssembly = CType(comp.Prototype, Part).ComponentAssembly
        Dim activeArr As Arrangement = c.ActiveArrangement
        For Each child As NXOpen.Assemblies.Component In comp.GetChildren()
            Dim IsSuppresed As Boolean
            Dim theSuppressedState As ComponentAssembly.SuppressedState
            theSuppressedState = c.GetSuppressedState(child, activeArr, IsSuppresed)
            If theSuppressedState = 2 Then
                Dim cDescr As compDescr = Nothing
                If ReadAttribiute(child, cDescr) = True Then
                    allComp.Add(cDescr)
                    getAllComponents2(child, allComp)
                End If
            End If
        Next
The problem is: This code ask about active arrangement for PART, no for COMPONENT ASSEMBLY.
The same sub-assemblies in one assembly have different arrangement, and I have always that same value.
Trying with child.OwnigPart.ComponentAssembly work that same.
I must find method to change "comp" to "c" with information about instance of this component.
Dim c As ComponentAssembly = comp ????? ComponentAssembly
I think solution in near but my head is empty.
Maybe somebody can help.
Best regards
MANok
NX2027
TC14
Thanks cowski.
this is it.
Best regrards
MANok
NX2027
Tc14
