Select many surfaces
  • Thread starter Thread starter MichailS
  • Start date Start date
M
MichailS
Guest
Hello
Is there some way to mass-select surfaces in Inventor?
I have imported a STEP file of a plastic component with a complex shape. In the process, every surface was assigned a certain color so if I change the visual style the color does not change.
I thus need to select every small fragment of surface and choose Properties and set Face Color Style to As Part, but this requires me to manually hunt and CTRL-peck on every surface of the object. This is a quite arduous task.
So: Is there some way to just drag a square so that every pertinent entity within it is captured?
Thank you
