Section Cuts not showing Diagram in SAP200
emosaka
3
Hi all,
I've been modelling a open-footed culvert on SAP2000 and am now doing section cuts via the "draw section cut" option. The top of the slab worked fine but when I try to section cut the wall the bending moment diagram is not given. See attached, this is an image of the top slab section cut with bending moment diagram. When I do a section cut of the wall though only the values are shown (no diagram).
Any suggestions? Is this a limitation of drawing section cuts?
Thanks! Stay healthy.
 https://files.engineering.com/getfile.aspx?folder=968d19c8-b3e1-4704-b433-351f550c975c&file=BMD.PNG
You should repost this software question here: forum801
Thanks JAE! I will do that. All the best!
