JLSE
- Oct 2, 2018
- 62
Continue thread507-240452
I'd like to stick with the code as much as possible (ie- no ESR reports), but I am not sure what 'approved fasteners' means (SDPWS 4.2.6.3).
Where do you go to find other 'approved fasteners', in the code?
I was always taught, in southern Ca., not to use the withdrawl values for nails, at all. I currently find myself, designin an Open Building, using horizontal 2x6 T&G plank roof decking for a diaphragm. The code specifies the use of 16ds at each support, and end.
However, there is a substantial uplift due to wind. So, I am looking for a solution whereby I can utilize the ductility of a nail, and the uplift resistance of a screw (or sim).
One option is to use screws in lieu of nails, but I haven't found a ductile screw... and don't expect to.
One option is to use a combination of nails and screws, if they are compatible... and I have not found any orgainization or documents recommending this combo.
One option is to go with the uplift values of the ringshank nail... but I am not familiar with this nail at all...
Anyone found a good/better solution for this type of combined condition?
And, has anyone had good experiences specifying ringshank nails for floor diaphragms, in regards to eliminating the 'squeek'?
