Hi,fiends
Currently we receive from a provider a screw pump ALLWEILER manufacturing lubrication associated with a pump of the coker. The pump is attached directly to the shaft of the pump of the coker. The problem is that pump we receive works in the opposite direction CW when really should operate in CCW direction.
Can I install this pump by turning in the opposite direction with the solution exchange the suction and discharge lines?
There any problems in pressure or discharge by turning in the opposite direction?
Their recommendation will be well received
Thanks...
Thanks...
