scaling/resizing question
  • Thread starter Thread starter peolini
  • Start date Start date
P
peolini
Guest
Hello All,
I'm very new to this forum.
I have been searching for a while but can't seem to find the answer to a question I have for some time.
I know the "scale" option in SW, but that only gives me a the possibility to scale parts in percentages of the original.
But, is there a way to resize parts just by typing in a new size/dimension?
Hoping on some positive feedback and thank you in advance,
Dennis
Is not clear for me what you wish to achieve.
If you wish to scale you say that you know how to.
If you wish to resize you can edit the sketch and replace old values for dimensions with new values.
Or:
- double click the part - this will show all dimensions;
- double click a dimension and input the new value;
- click REBUILD button.
Hello Mihail,
Thanks for replying.
I am trying to resize a complete part like this:
http://i265.photobucket.com/albums/ii229/peolini/cylhead.jpg
Themain bodyis now drawn about47 x 28 x 15,5 mm (lxbxh)
and I would like to reducethe entire partin size to about 5 x 3 x 2 mm just by punching in 5 for x, 3 for y and/or 2 for z without having to work out the exact percentages first.
I hope this makes sense,
Dennis
Unfortunately steel that have no sense.
I compute your dimensions this way:
Old_x = 47 New_x = 5 => New/Old = 0.106
Old_y = 28 New_y = 3 => New/Old = 0.107
Old_z = 15.5 New_z = 2 => New/Old = 0.129
So you have different scale in each direction.
Say that, for linear dimensions, can be done (mathematical).
But how to use different factor of scale for the circles (cylinders) ?
Will become ellipses, isn't it ?
Note that SW is not as intelligent as a human.
So, even if you have only linear dimensions, SW will refuse to do the
job because it "know" that it is not a general method to do that.
Hello Mihail,
Thanks again for replying.
>True, but my method would be like I am doing a 3D sketch of the part that looks good and after that I want to givethe partthe right dimensions.
At least that is the idea.
> yes it will become an ellips, I know that. which would be no problem to me.
So, even if you have only linear dimensions, SW will refuse to do the job because it "know" that it is not a general method to do that.
OK so I know I will not have to search any further for a solution.
I will just do it the "hard" way and scale parts proportionally.
Thank you for your explanations.
Dennis
