RSP file
nmnm87
Computer
Sep 27, 2005
18
I have a file with an RSP extension and I have never heard about it before , what program shall I use to opne it
thnaks alot
it is suppsoed to be a text file and it does not open with the note pad , microsoft word , adobe , or any part at all
thnaks
Right click on it, select 'open with', and select notepad from the list. If it is indeed a text file, notepad will open it okay. If Notepad doesn't complain, check the box to use Notepad to open files with that extension in the future.
What I do instead of that, is put a copy of or a shortcut to Vern Buerg's "list.com" in the directory |Documents and Settings|Default User|SendTo. Then I can right-click on any file and Send it To 'list', which will display its contents without modifying the file or getting confused.
Mike Halloran
Pembroke Pines, FL, USA
.rsp file extension is Allen Bradleys RS5 plc
software. use this to open.
