P
Peterhh
Guest
Hello
I am experiencing a problem with assembly dimensions being rounded in the window. This example shows 2 on the window and 2.438 in the ribbon. This would not be a problem if it was only the displayed value but when you click on the dim in the window and then enter "+.25" the dimension changes to 2.25 not 2.436+.25. I was looking for some wisdom from the board to find out if this is a config setting that does this or if it is truly a bug in Creo. To compound matters, when you drag the component to the other side of Zero the number goes to the default 3 decimal places and works normally.
Thanks in advance.
Peter Hoogeveen
llo
Hello
Thanks in advance.
Peter Hoogeveen
llo
