round external corners
  • Thread starter Thread starter penjas14
  • Start date Start date
P
penjas14
Guest
Is there a way to have pro e automatically round outside corners when finishing walls to a given radius, such as .01". I have tried "corner round radius" and "smooth sharp corners" with a radius in the "smooth radius". But when i run it in vericut the radius doesn't show up. If i draw the fillet into my mill volume it shows up, so its not too small to see. I am using a pocket routine in volume milling. I am using WF3.
Thank you in advance.
I think you might need to model the radii in to your part. Hopefully that is an option for you adding rounds using intent edges is my suggestion.
