rotation in assembly
  • Thread starter Thread starter kavita_verman
  • Start date Start date
K
kavita_verman
Guest
i am making a water proof box. in which i have used hinge.
i want to check whether the cover of the box rotates with
respect to the hinge or it fouls some where. how to rotate
a component in assembly mode? please help.............
when you assemble/edit definition component in assembly, beside placement there is tab called "move"..select motion type: rotate, motion reference and select axis of rotation...then drag component..
other way (If you got mechanism) is to define mechanism connection..that will detect collition between part
You can define a pin connection between the box and cover.
You do not need the mechanism module to use a pin joint.
See this video for reference:
http://communities.ptc.com/videos/2531
After you define this connection, under tools->assembly
settings->collision detection settings, you can set the
option to highlight interfering volumes.
Edited by: MGortner
