K
kbka
Guest
Hi
Ijust started using pro/engineer wildfire 3.0. I've drawn a simple engine, with a crankshaft, piston and piston rod. I've made the assembly and would like to add a servo motor, making the crankshaft rotate around it's own datum axis. How do I add this servo motor?
Help is much appreciated
