JSMHA
- Aug 25, 2021
- 6
For a rooftop screen, I have read that provisions for wind loading on rooftop equipment can be used if the screen is set in enough from the exterior wall. Otherwise, parapet loading should be used. This appears to be primarily for Components and Cladding load, as ASCE 7-16 Section 27.3.4 provides MWFRS values for parapets with GCpn of 1.5 for the windward parapet and 1 for the leeward parapet. ASCE 7-16 Section 29.4.1 is supposed to cover wind load on rooftop structures, but uses a GCr of 1.9 (assuming the area does not allow a reduction). This means the roof screen would actually produce more MWFRS wind than a parapet if it is treated as a rooftop structure, but less pressure for C&C. I am wondering what other engineers use for the MWFRS loading contributed by roof screens.
