Ronthewood
Industrial
My job is not in engineering, I'm actually a furniture maker and I'm stuck, and I hope you knowledgeable folk can help me out.
All the wood I use comes from within a 5 mile radius, I buy the trunks from local landowners/forestry, sawmill it, dry it and then make domestic furniture.
My sawmill is a "Swivel Saw". A head unit with engine and circular saw blade runs fore/aft on a pair of aluminium beams (250mm deep) with a rise/fall mechanism.
The head unit frame has 4 slotted rollers at its extremities and these rollers run on the aluminium beams. It's basic but has worked well for 20 years.
There's quite a load on the rollers and a couple need replacing. Needless to say the spares are no longer available and I can't find any substitutes.
My plan now is to buy some plain rollers and machine slots in these rollers to match up with the original design. I had one made a few years ago at a local machine shop, he only had nylon in stock, it was ok but this is already showing signs of wear.
So, my question to all you knowledgeable materials engineers is: What material would be best for the outer of the roller so that it will last ok but doesn't wear out the aluminium beam. I've seen these rollers at about the right size (60mm x 20mm) in a range of different materials (urethane, nylon, Vulkollan, phenol and so on...I'm a wood man!) but I'm not sure which has the right properties for my application.
Any advice very much appreciated.
Ron
Ron
