RISA 3D Misbehaving 1
OH_PA_AISC
All;
Over the years I have utilized RISA 3D analysis for non-buildings, large weldments evaluation for the material handing industry along with crane systems (runways and girders). I have made good use of both ‘Select Element by Property’ and ‘Quick Find’ especially with Auto Zoom feature activate. Unfortunately, Select Element by Property has been misbehaving. Under the Thickness Range, looking for small ¼” plates, search results yielded also 5/16” plates out of the specified size range. Other searches produced the desired plates thickness that were requested. Question to All – are you experiencing similar results?
Thanks for reading.
What version of RISA 3D are you using?
19.0.4 - Should be the latest.
Last time I tried to switch to the new interface (version 18+), there were still some glaring issues with how the reports were printing (missing headings and information). With that, I am still on version 17 of the software as they continue to work out many of their bugs - sounds like you may have found another one.
