Bill3752
Chemical
- Jan 24, 2008
- 138
We are looking at a reverse flow case. Normally liquid CO2 flows through a reciprocating pump, then is combined with vaporized CO2, the combination is a vapor. A PHA team found a potential source of overpressure on the suction side of the pump should the pump be shut down. We are modeling the reverse flow case by assuming an orifice at the PD pump.
Referring to the attached sketch, I am looking at three cases. In case 1, at the beginning of the scenario, liquid CO2 will flow back from C to B through the "orifice" and relieved at A. Skipping to case 3, in the later portion of the relief after the liquid had been removed the system will be filled by vapor, hence D to B. The relief from both are OK.
It is case 2 that I am interested in gaining input. Assuming for a minute that we have "plug" flow through the system, consider the situation wherein there is vapor at point B, and liquid from B to A. I am thinking that as the vapor pushes the liquid ahead of it, I must handle the volumetric rate of liquid that would be displaced by the vapor (not the mass rate). I.e., I am assuming that if the volumetric rate of vapor through the orifice is 250 cfh, then I must relief 250 cfh of liquid.
How have you handled this "vapor pushing liquid" in the past?
On a separate note, how do you deal with reverse flow through a reciprocating piston pump - is this considered a viable scenario?
