Return to last save
  • Thread starter Thread starter microplus+
  • Start date Start date
M
microplus+
Guest
Having alternated between using SDRC Ideas and Pro/E, I still get frustrated that there is no equivalent to the Ideas ^C switch which takes the user back to the last saved model. Is there such a thing within Pro/E.
Hi
Yes it is
Open
All Versions
and you can oppen last saved Version
Good luck
First
- try to explain little more your problem.
Second
- when you save your part in ProE, you always have opportunity to look into
working folder and to choose what save will you load. Whenever you save
something in ProE, it stays on HDD and get another (next) number
test.prt
test.prt.1
test.prt.2
<div style="border-style: none none dotted; border-color: -moz-use-text-color -moz-use-text-color windowtext; border-width: medium medium 3pt; padding: 0cm;">
test.prt.3
</div>
test.prt.111
I assume you want to basically undo everything since the last save, is that right? In that case you can hit the file/erase/current to flush it from memory and then open it again. Not as easy as ^C, maybe you could make a mapkey.
if you are on Intralink, dont forget about frame reports/frame undo...
try to see by the option in "open" window using all version.....
