EngDM
- Aug 10, 2021
- 729
Hey all,
I've been looking through some manufacturers catalogues (namely Bailey) and they only provide the lateral load capacity where the load is applied by a single stud. Does anyone know the approach to determining the capacity for when the load is applied by a steel stud post with multiple ply's? I'm trying to determine whether or not the use of a clip from the steel stud directly into the steel beam above is necessary, or if the two screws will suffice.
