You are correct Jay about selecting the same tool twice. The tool is describe as aDrill (used for Spot drilling in the seq.)and the other as Milling (Used for chamfering corner break around the part). I hope this is what you are looking for on the C/L data.
PPRINT / NC SEQUENCE COMMENTS
PPRINT / SPOT DRILL BOTH SIDES
LINTOL / 0.010000
PPRINT / TOOL COMMENTS
PPRINT / T77490-1 SPOT DRILL
LOADTL / 2 $$-> T77490-1 SPOT DRILL
$$-> CUTTER / 0.250000
SET / OFSETL, 54
$$-> CSYS / 1.0000000000, 0.0000000000, 0.0000000000, 0.0000000000, $
0.0000000000, -0.0000000000, 1.0000000000, 0.0000000000, $
0.0000000000, -1.0000000000, -0.0000000000, 0.0000000000
SPINDL / RPM, 3500.000000, CLW
COOLNT / ON
RAPID
GOTO / -5.69002410, 1.00000000, -0.09160350, $
0.00000000, 1.00000000, -0.00000000
CYCLE / CSINK, DIAMET, 0.150000, TLANGL, 90.000000, IPM, 15.000000, CLEAR,$
0.100000
GOTO / -5.69002410, 0.27500000, -0.09160350, $
CYCLE / OFF
RAPID
SET / OFSETL, OFF
COOLNT / OFF
SPINDL / OFF
$$-> END /
$$-> FEATNO / 8900
LOADTL / 2
$$-> CUTTER / 0.050000
SPINDL / RPM, 5000.000000, CLW
COOLNT / ON
RAPID
GOTO / -6.66776061, 1.00000000, -0.51221406, $
RAPID
GOTO / -6.66776061, 0.47600000, -0.51221406, $
FEDRAT / 60.000000, IPM
GOTO / -6.66776061, 0.32721406, -0.51221406, $
CUTCOM / LEFT, 2
FEDRAT / 20.000000, IPM
GOTO / -6.66776061, 0.32721406, -0.41221406, $
CIRCLE / -6.56776061, 0.32721406, -0.41221406, $
0.00000000, 1.00000000, -0.00000000, 0.10000000
GOTO / -6.56776061, 0.32721406, -0.31221406, $
GOTO / -6.17833958, 0.32721406, -0.31221406, $
CIRCLE / -6.17837331, 0.32721406, -0.08500000, $
0.00000000, -1.00000000, 0.00000000, 0.22721406
GOTO / -5.95889084, 0.32721406, -0.02623204, $
GOTO / -6.03299385, 0.32721406, 0.25032420, $
GOTO / -6.07857652, 0.32721406, 0.20467562, $
GOTO / -6.07857079, 0.32721406, 0.20466990, $
CIRCLE / -6.75968138, 0.32721406, 0.88479138, $
0.00000000, 1.00000000, -0.00000000, 0.96253668
GOTO / -6.94115765, 0.32721406, -0.06048277, $
GOTO / -6.94115591, 0.32721406, -0.06047363, $
CIRCLE / -6.96290662, 0.32721406, -0.17463410, $
0.00000000, -1.00000000, 0.00000000, 0.11621406
GOTO / -7.07516078, 0.32721406, -0.20471252, $
GOTO / -7.06943360, 0.32721406, -0.22608663, $
CIRCLE / -6.95718164, 0.32721406, -0.19600000, $
GOTO / -6.95718164, 0.32721406, -0.31221406, $
GOTO / -6.46776061, 0.32721406, -0.41221406, $
CUTCOM / OFF
GOTO / -6.46776061, 0.32721406, -0.51221406, $
RAPID
GOTO / -6.46776061, 1.00000000, -0.51221406, $
COOLNT / OFF
SPINDL / OFF
$$-> END /
$$-> FEATNO / 8493
0.0000000000, 0.0000000000, -1.0000000000, 0.0000000000, $
0.0000000000, 1.0000000000, 0.0000000000, 0.0000000000
SPINDL / RPM, 3000.000000, CLW
COOLNT / ON
RAPID
GOTO / -5.69002410, -1.00000000, -0.09160350, $
0.100000
GOTO / -5.69002410, -0.27500000, -0.09160350, $
CYCLE / OFF
RAPID
COOLNT / OFF
SPINDL / OFF
$$-> END /
$$-> FEATNO / 8897
PPRINT / MILL CORNER BREAK
LOADTL / 2
COOLNT / ON
RAPID
GOTO / -5.82029202, -1.00000000, 0.22925080, $
RAPID
GOTO / -5.82029202, -0.47600000, 0.22925080, $
GOTO / -5.82029202, -0.32721406, 0.22925080, $
CUTCOM / LEFT, 2
GOTO / -5.91688460, -0.32721406, 0.20336889, $
CIRCLE / -5.89100270, -0.32721406, 0.10677631, $
0.00000000, -1.00000000, 0.00000000, 0.10000000
GOTO / -5.98759528, -0.32721406, 0.08089440, $
GOTO / -5.95889284, -0.32721406, -0.02622455, $
CIRCLE / -6.17837331, -0.32721406, -0.08500000, $
0.00000000, 1.00000000, -0.00000000, 0.22721406
GOTO / -6.17833200, -0.32721406, -0.31221406, $
GOTO / -6.95719063, -0.32721406, -0.31221406, $
CIRCLE / -6.95718164, -0.32721406, -0.19600000, $
0.00000000, 1.00000000, -0.00000000, 0.11621406
GOTO / -7.06943578, -0.32721406, -0.22607849, $
GOTO / -7.07516173, -0.32721406, -0.20470898, $
GOTO / -7.07515554, -0.32721406, -0.20470732, $
CIRCLE / -6.96290662, -0.32721406, -0.17463410, $
0.00000000, 1.00000000, -0.00000000, 0.11620765
GOTO / -6.94111233, -0.32721406, -0.06048846, $
GOTO / -6.94111135, -0.32721406, -0.06048336, $
CIRCLE / -6.75968138, -0.32721406, 0.88479138, $
0.00000000, -1.00000000, 0.00000000, 0.96252853
GOTO / -6.07856866, -0.32721406, 0.20468358, $
GOTO / -6.03299410, -0.32721406, 0.25032512, $
GOTO / -5.86512079, -0.32721406, 0.01018373, $
CUTCOM / OFF
GOTO / -5.76852821, -0.32721406, 0.03606563, $
RAPID
GOTO / -5.76852821, -1.00000000, 0.03606563, $
COOLNT / OFF
SPINDL / OFF
$$-> END /
Thanks, Alan
